Title | Size | Downloads |
01-Fundamentals Command Reference-book.pdf | 955.56 KB |
Preface
The H3C S5500-SI/EI documentation set includes 10 command references, which describe the commands and command syntax options for the S5500-SI and S5500-EI Series Ethernet Switches, Release2208.
The Fundamentals Command Reference describes commands for configuring command line interface (CLI), logging in to your switch, configuring FTP and TFTP, file system management, configuration file management, device management, and software upgrade.
This preface includes:
· Audience
· About the H3C S5500-SI/EI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-SI/EI series
Added and modified commands
Compared to Release2202, Release2208 adds and modifies the following commands:
Command reference |
Added and modified commands |
CLI |
Added commands: super authentication-mode Modified commands: Added regular-expression related parameters to all display commands |
Logging in to the switch |
Added commands: · command authorization · command accounting |
FTP |
Modified commands: ftp—Added support for the vpn-instance keyword (available only on the S5500-EI) |
TFTP |
Modified commands: tftp—Added support for the vpn-instance keyword (available only on the S5500-EI) |
File management |
Configuration file management |
Modified commands: save—Added support for the force keyword |
Software upgrade |
Added commands: boot-loader update file |
ISSU (available only on the S5500-EI) |
ISSU related commands are newly added to this release |
Device management |
Added commands: · job · time at · time delay · view · temperature-limit |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
The H3C S5500-SI/EI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
PSR150-A [ PSR150-D ] Power Modules User Manual |
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products. |
RPS User Manual |
Describes the appearances, features, and specifications of the RPS units available for the products. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Interface Card User Manual |
Describes interface card appearance and specifications. |
Hardware installation |
Quick Start |
Provides regulatory information and the safety instructions that must be followed during installation. Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Installation Guide |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Describes how to install an interface card. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
H3C Series Ethernet Switches Login Password Recovery Manual |
Describes how to find or recover a lost password. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
